Author Topic: Adding parameters to operation  (Read 5865 times)
SomersetGraham
« on: November 11, 2011, 02:13:27 am »
Hi
Has anyone else observed this behavior?
Open the operation dialog for a class
Add a new operation
Now use the 'Edit' button to add parameters
I cannot type in any information
I have to save the operation and close the dialog, then reopen it to enter parameter info.
If, however I type the parameter info directly into the Parameters text box everything is OK ::)
Graham
Using V12
Luis J. Lobo
  • IT Consultant
Re: Adding parameters to operation
« Reply #1 on: November 11, 2011, 03:04:35 am »
Yes, it's a UI bug.
SomersetGraham
« Reply #2 on: November 11, 2011, 03:05:11 am »
Do you know if its been reported?
Using V12
Luis J. Lobo
  • IT Consultant
« Reply #3 on: November 11, 2011, 03:06:12 am »
I don't think so. I discover it yesterday but not reported yet.
SomersetGraham
« Reply #4 on: November 11, 2011, 03:11:44 am »
just reported it
Using V12
SomersetGraham
« Reply #5 on: November 11, 2011, 07:16:22 pm »
Response from sparx
This is a known issue which is currently scheduled to be fixed in the next build of Enterprise Architect.  The tracking ID for this issue is 11059223.
The Operation needs to be saved before you can add/edit parameters.  You should not need to close the Operations dialog however.  In our testing using build 910, we were able to edit Parameters immediately after saving the operation without closing the dialog.
In a future releases, EA should prompt to save the operation first before editing parameters.
Using V12
