Author Topic: Performance issue with 9.1.910 on SQL Server  (Read 11708 times)
« on: November 09, 2011, 11:18:54 pm »
Opening a diagram in version 9.1.910 takes 30 seconds (or more) where the diagram diagram is opened in 9.1.909 in less then 2 seconds.
So I've downgraded now :(
Bug report with the the query that was to blame sent to Sparx.
Re: Performance issue with 9.1.910 on SQL Server
« Reply #1 on: November 11, 2011, 03:08:05 pm »
Hi Geert,
Did the query change between releases?
« Reply #2 on: November 11, 2011, 03:36:11 pm »
Yes,
The added two selects in the union that include something like "t_object.PDATA2 LIKE t_xref.Client
This LIKE statement causes SQL Server to do a full table scan on t_xref (twice)
The previous version didn't have those selects in the list of unions.
« Reply #3 on: November 11, 2011, 09:02:13 pm »
Is it just certain diagrams or will that effect any diagram?
« Reply #4 on: November 11, 2011, 09:24:25 pm »
All diagrams
The same query is used each time a diagram is opened, and because of the table scans it doesn't matter which diagram you are loading.
It might not be a problem in other databases.
« Reply #5 on: November 12, 2011, 12:47:07 am »
When you say SQL Server you probably mean MS SQL Server - which is the one we recently moved to. Well, most of our diagrams are small so it might not be an issue at all. However, we're warned  now.
Thanks, q.
« Reply #6 on: November 12, 2011, 01:31:07 am »
Yep, I mean MS SQL Server (2008)
The size of the diagrams doesn't matter, only the size of the table t_xref.
We have about 163.000 records in it (mainly because of all the "column" steretoypes for the imported databases)
« Reply #7 on: November 16, 2011, 12:40:45 pm »
We've also rolled back to 909 and performance has improved an order of magnitude - to confirm Geert's findings.
This needs to be fixed ASAP!
« Reply #8 on: November 16, 2011, 02:19:18 pm »
This will be corrected in the next build.
Sorry for an inconvenience caused.
« Reply #9 on: November 16, 2011, 06:00:54 pm »
Ah, good to know Simon.
Where exactly do I send my invoice to  ;D
MMA
« Reply #10 on: November 17, 2011, 01:25:13 pm »
It is fast in 9.2 now, cheers
« Reply #11 on: November 17, 2011, 03:27:11 pm »
Confirmed...  On a quick test about 20% slower than under 909.
« Reply #12 on: November 17, 2011, 08:38:31 pm »
You mean this is a re-definition of "fast"?
« Reply #13 on: November 17, 2011, 09:04:53 pm »
Well,
If look at it this way:
9.1.909: 1 second
9.1.910: 34 seconds
9.2.920: 1.2 seconds (+ 20%)
So yes, compared to 9.1.910 an impressive performance improvement  :P
« Reply #14 on: November 18, 2011, 12:46:50 pm »
Well,
[size=18]...[/size]
However, I'm also testing on a functionally equivalent EAP file (to the SQL DB) and I'm seeing 920 as 2-3 times slower than 909.  Anyone else seeing this?
I'm preparing some formal test sets to compare longish (enough) runs to get a good comparison.  I'll post the results here.
Sparxians, should we be seeing these types of numbers (especially on EAP files)?
[edit]I've documented my findings with EAP files in: Performance issue with 9.2.920 on EAP files[/edit]
« Last Edit: November 18, 2011, 07:50:58 pm by PaoloFCantoni »
