Author Topic: Object changes not saved  (Read 4181 times)
bch
« on: November 08, 2011, 11:39:28 am »
The information is not saved when attempting to paste a short sentence from a Word document to the Notes field in a requirement.
The operations is successful if the clipboard is pasted into notepad, re-copied and pasted into the Notes field.  This might suggest the formatting characters are the cause.
Not sure how to attach a Word document to illustrate the example??
Re: Object changes not saved
« Reply #1 on: November 08, 2011, 05:55:40 pm »
Yes,
I've seen strange things happening when pasting from Word or other non-plain-text sources.
I just try to avoid it.
« Reply #2 on: November 09, 2011, 09:22:00 pm »
You should try to copy/paste from PDF to Lotus Notes. That's even more strange. However, you should report a bug if you can reproduce it.
Rixon
« Reply #3 on: November 21, 2011, 10:25:56 pm »
Did someone get thru attaching any office document with the EA model??
« Reply #4 on: November 24, 2011, 12:09:00 am »
You should use a hyperlink for any such advanced references.
Further you have a Files section where you can add links.
« Last Edit: November 24, 2011, 12:09:37 am by qwerty »
