Author Topic: Unable to resize Message Properties form  (Read 3898 times)
AmirH
« on: December 21, 2011, 08:20:13 pm »
It is not convinent choosing between messages, where message string size is more than 31 characters. Such long function name is very populare when dealing with C code, and especially when such code is reverse engineered and imported into the model.
One option to ease such task is to allow resizing the Message Properties form so such long methods would be displayed completly when opening the messages combobox.
Can you support this?
Thanks in advance,
AmirH
Re: Unable to resize Message Properties form
« Reply #1 on: December 21, 2011, 09:57:07 pm »
Place your request here: http://www.sparxsystems.com/cgi-bin/yabb/YaBB.cgi?num=1277328078. Additionally send an official feature request to Sparx (link at the bottom of the page).
I also support that as we had the same issue some time ago. Because we needed some solution we found a way around (by choosing shorter names) and did not submit a feature request.
AmirH
« Reply #2 on: December 22, 2011, 12:03:41 am »
10x
I moved it to the suggestions & requests section.
AmirH
