Author Topic: Code Generation changing attribute names  (Read 9439 times)
Adrian P
« on: December 28, 2011, 06:43:56 pm »
Whenever I do a Code Engineering -> Generate Source Code and then click Generate, the code is generated as expected, but all attributes that exist in the model wind up prefixed by m_ and the first letter capitalised. So for example, accessInteractionTable becomes m_AccessInteractionTable.
I have changed every variable I can find that seems related to this and still it occurs. I attempted to change the "Remove prefixes when generating Get/Set properties" on the Source Code Engineering options page, Removed m_ from the Default name for associated on the Attribute/Operations page, and can't see anything related on the C# page. I have even looked in the Code Generation Templates and can't see anything related.  :(
Am I missing something here or is there an actual fault?
Adrian Pavone.
Re: Code Generation changing attribute names
« Reply #1 on: January 05, 2012, 08:58:34 am »
I haven't seen anything like that before.
The only thing that I can think of that could cause the name to be generated differently would be the code templates. Specifically the Attribute Declaration and Linked Attribute Declaration templates.
