Author Topic: Windows Authentication Fails on Network Drive  (Read 4923 times)
Jonathan Warner
« on: January 05, 2012, 08:02:58 pm »
Hi
I've encountered a problem authenticatin users added from Active Directory to an EA project.
- The project is in an Access file (.EAP). [I have no other option at the moment]
- If I have the project on my local disk, windows authentication works fine
- If I move the project to a shared drive, and try to connect to the project, I am prompted with the login window.
Any suggestions?
EA version 9.2 (build 921)
Cheers
-Jonathan
Re: Windows Authentication Fails on Network Drive
« Reply #1 on: January 05, 2012, 09:28:13 pm »
Works as designed. When you move your EAP with imported users, they are invalidated.
« Last Edit: January 05, 2012, 09:29:03 pm by qwerty »
Jonathan Warner
« Reply #3 on: January 08, 2012, 04:34:00 pm »
Thanks for the replies.
Sorted.
-Jonathan
