Author Topic: RTF Documentation Template  (Read 4183 times)
Niy
« on: December 20, 2011, 12:50:47 am »
EA 8.0.864
As soon as I start to use parameter > in the Table it only generates the first {MethodName}
Try1:
Try2:
Try3 (this works since there is no parameter)
output: this is what I get out of Try2
Well.. Is there a workaround?
Kind regard, Niy
« Last Edit: December 20, 2011, 12:53:11 am by Niy »
Niy
Re: RTF Documentation Template
« Reply #1 on: December 20, 2011, 10:34:17 pm »
Ok,
the problem is the parameter within the table, it kinda messes it up.
Solution is creating an invisible first tablerow.
Doug Blake
« Reply #2 on: January 04, 2012, 07:40:01 pm »
Is there something better than image shack you can use. I got popups I couldnt close from it, unless I shut IE9 down altogether.
DGB Using 12.0.1214 / eaDocX 3.6.2.1 / MSSQL / TFS / Windows 7 / IE11
Niy
« Reply #3 on: January 09, 2012, 08:03:55 pm »
Isn't there anything better than IE9 you can use?  ::)
Well actually there isn't: I'm behind a firewall and most pichosters are blocked by it, imageshack isn't.
