Author Topic: Tagged Values in MDG Technologies  (Read 3608 times)
Ross@NZ
« on: January 13, 2012, 08:34:52 am »
I am working on an MDG technology where I want to use  Tagged Value types as attributes for my Stereotyped elements
I have a Tagged Value Type called Owner - which is a lookup
If I add a Attribute call Owner to a stereotype - generate my MDG and it uses the lookup - but only in the EAP that the Tagged value is defined in.
When I include the profile and the taggedvalue in a MDG the only way to reference the Tagged Value is to use the MDG ID as a namespace preceeding the tag name.
I.e MYMDGID::Owner which while it works is not very friendy.
How can I bind the Tagged Value to the stereotypes Tag without having the use the prefix.
I have looked at the MDG Sparx Systems provide and they don't have this problem - however the tags appear differently in the output XML file
Example
Sparx Systems: This works
<Tag name="SubProcessRef" />
My MDG: Doesn't work
<Tag name="SubProcessRef" type="int" description="" unit="" values="" default="1" />
Clearly there is a difference. Is there a process that I need to follow to make it work for me.
I know that I can use the tagged value connector in the Profile for Guid lookups but I have the same problem with DatetTme Tagged Values and other Types that I am using.
Looking forward to your reply
Regards
Ross
« Last Edit: January 13, 2012, 08:36:18 am by RossNZ »
Re: Tagged Values in MDG Technologies
« Reply #1 on: January 13, 2012, 10:37:45 am »
I had the same issue but no solution except to re-define the tagged values with the default tagged value editor. I reported that some time ago as a bug (that tagged value types are not respected in the MDG) and IIRC it had been recognised by Sparx. But no solution so far.
[edit:] I scanned my mail and added the bug in my list here: http://www.assembla.com/spaces/enterprise-architect/tickets/59-mdg-and-tagged-values
« Last Edit: January 13, 2012, 10:51:14 am by qwerty »
