Author Topic: Problem trying to set a section to Landscape mode  (Read 4226 times)
GeoBull
« on: February 15, 2012, 01:36:10 pm »
Version info:
EA 9.2.921
Windows 7
Goal: Set a section of a report template to be in Landscape mode
Repro steps:
1. Put cursor where you want the landscape section to start
2. Insert Section Break using right-click menu
3. Put cursor where you want the landscape section to end
4. Insert Section Break using right-click menu
5. Put cursor somewhere between the two section breaks
6. Edit Section and set to landscape using right-click menu
EXPECTED RESULT
That section and only that section is in Landscape mode
ACTUAL RESULT
Not consistent but sometimes from that point forward the entire document is in Landscape mode. Or from that point to top of document is in Landscape mode. Or the entire document is in Landscape mode.
Related issues:
-Can't see the section breaks; even with Page Layout View
-Therefore, can't delete section breaks
-Hard to know where to put section breaks: Right where a model section starts? Right at a section header (text) where you want the section to start?
« Last Edit: February 15, 2012, 01:37:03 pm by GeoBull »
cRossi
Re: Problem trying to set a section to Landscape mode
« Reply #1 on: November 13, 2018, 10:30:26 pm »
This topic is still active and not working correct in the current Version 14 !
