Author Topic: Version 4.00 - Build 722 Released  (Read 21181 times)
sparks
« on: March 22, 2004, 08:59:57 pm »
Release Notes for EA 4.00 Build 722
Fixed problem with UML 2.0 style components when stereotyped with web profile stereotypes. Icon display and component size could be adversely affected
Fixed problem with bounding rectangle calculation when dependent and provided interfaces automatically shown on element
Fixed error wherebye Element "file" dialog duplicated record when name changed, rather than amending it
Fixed error where a deleted elemented could in some cases cause an exception to occur
Fixed problem with SQL Server when loading a new project may throw DB error on Stereotype table
Added ability for Activity to show Tagged Values when draw in Rectangle mode
Some changes to XMI importer to improve import of Telelogic XMI 1.0 exports
Added ability for Activity element whan draw as a Rectangle style to show Tag, requirement and Constraint compartments
Fixed problem with same link in two diagrams currently open when one end of link deleted in one diagram
Fixed layout problem with Interfaces not being included in layout
Modified HTML report generator to link Composite elements (with child diagram) to their target diagrams in HTML image map
Modified EA to prevent dropping duplicate copies of the same Package in a diagram
Added ability to launch files,edit operations and attributes and launch property window  from Element Browser window double click
Modified Undo feature to ensure local color settings for elements in a diagram are restored on undo
Modified "Delete froim Tree" method to ensure multiple Ctrl+Del keypresses in quick succession did not causes program errors
Modified Interaction Fragment dialog to correct error with setting partition type that could occur
Improved Multi-Monitor support to correctly detect monitors to the left, above and below the primary monitor (as well as the normal to the right mode)
Modified EA to close newly created diagrams when importing directory structures - this to avoid many open diagrams when import structure is very large
