Author Topic: Getting packages from version control repository  (Read 3908 times)
davidb_dbd
« on: January 14, 2004, 10:50:59 am »
OK, I've set up version control in Project A, with a VSS Project and a local VSS folder. I've registered one package with version control and checked it in. I can check it in and out fine. I see the XML file within VSS and in my local folder.
Now I've created a new Project B, registered it with Version Control (same VSS Project, different local VSS folder).
When I go to Get Package from Project B, it gives me an EMPTY list of shared packages. I can't see the checked-in package at all.
What am I doing wrong?
--dpb
ditlev
Re: Getting packages from version control reposito
« Reply #1 on: March 02, 2004, 06:14:00 am »
I had similair problems. however, changing VSS user made a difference.
d
eduardgrosu
« Reply #2 on: March 03, 2004, 01:57:05 am »
Hi all.
When i follow the same steps with Jalindi Igloo seems to works. All shared packages are shown.
The same problem you described happened with Subway and ActiveCVS plug-ins. With VSS i did not try to check becouse have not Visual Source Safe.
My question is what plug-ins you recommend me for using Version Control in EA using CVS.
Good luck
Gred.
