Author Topic: something wrong on windows2000 platform  (Read 3105 times)
cyberhouse
« on: August 02, 2004, 10:29:19 pm »
i draw two use case: usecase1, usecase2.
when i extend usecase2 to usecase1, EA show an error:
DAO.Database[3075]
Syntax error in string in query expression " xtend?".
when i use prototypes  such as <<include>>, <<interface>>,  EA also show them incorrect.
the windows2000 platform is CHN or CHT
cyberhouse
Re: something wrong on windows2000 platform
« Reply #1 on: August 03, 2004, 12:50:05 am »
another problem:
when i delete an element in usecase diagram using 'delete' key, the project view doesn't delete the element at the same time.
this bug also appear in ms visio 2003.
Tjerk
« Reply #2 on: August 04, 2004, 03:13:04 am »
The latter one is a feature, not a bug. Delete only deletes items from the diagram, so you can use the item in the projectbrowser on other diagrams as well. Using the newest EA build (732) you can use Ctrl-Delete to delete the item from all diagrams and the projectbrowser at once (so be carefull).
