Author Topic: How to select proj elts verifying a condition  (Read 2428 times)
JP
« on: August 06, 2004, 02:43:38 am »
Is there a way to extract from the whole project tree structure elements verifying a specific condition based on (but not limited to) their attributes values, such as, for instance, "Status" field = "Validated". Idealy I would view these elements in th esame tree structure but with a different color.
More generaly is there a way to run (SQL ?) queries on the DB tables of the project (since the whole thing is a bunch of Access DB tables).
I assume this should be possible using Automation but I was wondering if there would be an already built in tool/function to do that.
I have a really big project and I need to be able to extract / view the elements or diagrams that have been "validated" or not by others.
JP
Re: How to select proj elts verifying a condition
« Reply #1 on: August 09, 2004, 05:07:50 am »
JP,
there is a built-in function to search element. It covers quite a lot of features but of course it has its limitations.  Try Edit/Find or Ctrl+F.
If you need more sophisticated search you can also go directly to the database. EAP-files are nothing else than MS Access databases. The table names are quite easy to understand and you'll probably be able to create queries in a short time. The table in question is t_object.
