Author Topic: Import package from XML problem  (Read 2956 times)
Vlad
« on: May 24, 2005, 10:50:34 pm »
I am continue evaluating your product.
Yesterday, I came across such problem or,  may be a bug.
I use CVS system for version control. EA uses the XML format files for the CVS server. When I checked out my project from the CVS I found that some links disappared from my project. I ckecked out the previos version and everything was all right.
Then I make some changes with my project (add some classes, use cases and links)  and export it into the XML file. When I created the new project and tried to import package from my XML file the following error message appeared:
DAO.Field[3163]
The field is too small to accept the amount of data you attemped to add. Try inserting or pasting less data.
What have happend? What can I do to avoid this problem?
I use EA ver. 5.0. but this problem was found also with ver. 4.51.
Re: Import package from XML problem
« Reply #1 on: May 25, 2005, 02:44:33 am »
Hi Vlad,
I had the same problem importing an XMI file and the links also failed to import.  Please formally report as a defect... via the http://[email protected] address.
