Author Topic: Creating State Transitions  (Read 2592 times)
tah2k
« on: January 17, 2006, 02:56:16 pm »
Hi-
I am evaluating Enterprise architect and I am trying to create a transition between a sub-state of a Sub-machine and another state at the same level as the Sub-machine. Since the sub-machine states are contained in a different page, I can figure out how to transition out and up in the hierarchy.
-Tim
Tuser
  • So much stuff to do, so little time...
Re: Creating State Transitions
« Reply #1 on: January 20, 2006, 07:02:29 am »
Solution 1;
In the sub-state diagram, create a Entry/Exit element. In the sub-machine diagram, drag and drop the Entry/Exit element onto the state supporting it and add it as an instance.
Cons are that EA does not seem to create a 'proper' Entry/Exit point, i.e. a 'port-like' element on the state that is attached to the boarder of the state. You have to do this by hand.
Pros are that you have a single Entry/Exit element, shown in to different diagrams.
Solution 2;
Select the sub-machine and right click. Then select 'Add Embedded Element' and add entry/exit points. Name them!
In your sub state diagram, use the special 'Entry' and 'Exit' elements.
To make life easier, name the entry/exit points in the sub-machine the same as the entry/exit elements in the sub-state diagram the same.
Cons are that you have two elements representing the same.
Pros are that you have a nice layout automatically.
Peronally I would go for solution 1. Is consistent.
