Author Topic: cannot generate C# interfaces  (Read 2598 times)
gtschech
« on: March 08, 2006, 04:42:31 am »
When modelling in EA, I can mark a class with the stereotypp <<interface>>.
After marking that clas as being coded in C#, I would have anticipated that the code would generate an interface, just as
public interface Idontknow
 void InterfaceMethod();
but EA generates a class, which is not what I need.
If I change 'class' to 'interface' in the source file, EA does not recognize this code any more and recreates the class.
How and where do I have to set flags so that the code generation actually produces an interface?
Guenter from Frankfurt/Germany
Re: cannot generate C# interfaces
« Reply #1 on: March 08, 2006, 01:02:28 pm »
You need to use an interface element.  (It appears in the class toolbox just under class.)
You can also change your class in the model into an interface.  (Element | Advanced | Change Type)
