Author Topic: Checkout failed with CVS  (Read 2803 times)
raf76
« on: January 05, 2006, 08:46:45 am »
I'm a new user to EA and I try to set up control version with CVS.
I'm using EA 6.0 build 781 and CVSNT 2.5.02 as repository. I am able to check files in and out from WinCVS as a client so I think the repository
is set up correctly.
Using EA, when I try to add a package to version control all seems to be well. However, when I attempt to check the package out of CVS I get a "checkout Failed". "Check In" and "Undo Checkout" cannot be selected (grey). I cannot remove package from version control becose the packages need to be checked in.
Thank to every suggestions
dedmoroz345
Re: Checkout failed with CVS
« Reply #1 on: April 04, 2006, 03:53:13 am »
Hi, I have a same problem. Did you find any solution?
Thank you for your attention
