Author Topic: Java "properties"  (Read 2904 times)
David Meyers
Java "properties"
« on: June 08, 2006, 07:25:10 am »
I'm attempting to generate getters and setters for a Java class's attributes.  When I click on the Properties check box of an attribute, I do not have the option of specifing the capitalization of the methods.  Is there a template or configureation that allows me to change this?
I would like my getters/setters to be:
getCode setCode
NOT
getcode setcode
thanks,
Dave
Re: Java "properties"
« Reply #1 on: June 08, 2006, 08:38:22 am »
Dave,
Take a look at Tools / Options / Source Code Engineering.
Near the bottom of the page you should see (under Remove Properties when...) a check box labelled Capitalized Attribute Name for Properties. I think you need to check this box.
In the Java page (still within Tools / Options) ensure that the prefixes are "get" and "set" (without quotes); these should be the default.
Now name the properties as you want. Remember that if you use a prefix not included in the list (back in the Source Code Engineering page) you will have to add that prefix to get the desired results.
