Author Topic: SSJavaProfiler5_70  (Read 3317 times)
DTebar
  • Zitterbewegung Rocks!
SSJavaProfiler5_70
« on: August 22, 2007, 06:59:10 am »
Hola!
I am trying to use the java debugger and attach it to the JVM. I am using NetBeans 5 and JDK 1.6.0. The command I use is "java -agentlib:C:\Program Files\Sparx Systems\EA\SSJavaProfiler5_70". But it gives me the following error when I select "Run Debug Main Project"
: ERROR: JDWP unable to get necessary JVMTI capabilities.
Then, there is nothing I can do and I'm stuck.
Any idea ? I need help.  ???
Thanks and Regards,
Daniel M. Tebar
UML Analyst
E-Mail: [email protected]
Tel: 813.362.5541
http://www.myspace.com/dtebar
bhupendra.2008
Re: SSJavaProfiler5_70
« Reply #1 on: February 07, 2008, 10:03:01 pm »
SSJavaProfiler5_70 is used for debugging java web sever so use  the following syntex if you are using to debug from java web server
java -agentpath:"C:\Program Files\Sparx Systems\EA\SSJavaProfiler5_70.dll"
Please also let me know if it doesn't work it out.
Thanks & Regards
Bhupendra
