Author Topic: Code generation with relative paths  (Read 2315 times)
frik_stuart
  • MDA is the future!
« on: June 21, 2007, 01:09:26 am »
Does anyone know of a way to forward engineer a model by using relative paths? The "Generate Package Source Code" dialog allows you to specify a Root Directory when the "Auto Generate Files" option is selected, however this always populates with the absolute path such as "C:\myproject\code", whereas I need to specify it as a relative path something like "..\code". I can't seem to find any way to specify a relative path here because the edit line is disabled.
This causes a problem for us because our source code is accessed via network drives (we use ClearCase for our CM system) and we also move the project locations from time to time.
« Last Edit: June 21, 2007, 01:12:55 am by frik_stuart »
Re: Code generation with relative paths
« Reply #1 on: June 21, 2007, 05:08:45 am »
Search for Local Paths in the help.
