Author Topic: image transparency  (Read 6578 times)
JohnDoe
  • EA rocks !
image transparency
« on: June 20, 2007, 02:18:59 am »
I want to use transparent images in my diagrams as alternate images. No matter whether I import PNG oder JPG or GIF or EMF, I always get a black background. Since the diagram background can be altered, I would like to build a set of transparent images.
Since the EA image library offers some transparent pictures: What format is it or how do Sparx achieve transparency ?
Regards
Bernd
« Last Edit: June 20, 2007, 02:37:43 am by BerndWill »
«Midnight»
  • That nice Mister Grey
Re: image transparency
« Reply #1 on: June 20, 2007, 02:30:55 am »
Bernd,
They don't seem to support transparency through version 6.5 inclusive. [Someone please correct me if I'm wrong.] Sparx has mentioned possible support in some as yet unspecified future version.
I don't know if this is handled in version 7.0. I have seen nothing in the first two beta releases that suggests it is, but then again I haven't tried this explicitly and the documentation has not yet caught up with the feature set.
If you have access to the beta - all registered users in good standing should, so check the Latest News section of the forum - then try it out. If the feature doesn't seem to work issue a bug report using the link on the beta download page.
This is an often-requested feature, and will only become more important as EA improves its ability to render custom shapes. I don't think it will ripen well if left on the shelf until version 8.0.
PS: Please post any response you get from Sparx to this thread. There is a lot of interest in the community.
No, you can't have it!
thomaskilian
  • Guest
« Reply #2 on: June 20, 2007, 02:31:06 am »
I'm not sure if this is the answer, but it could be Shape Script.
JohnDoe
  • EA rocks !
« Reply #3 on: June 20, 2007, 02:37:08 am »
If you open "Settings - Images", you can see all image library pictures marked as "Metafile", whereas my PNG files are marked as Bitmap.
thomaskilian
  • Guest
« Reply #4 on: June 20, 2007, 02:47:56 am »
So using EMF/WMF might be the answer?
«Midnight»
« Reply #5 on: June 20, 2007, 03:18:37 am »
Perhaps not.
I remember (perhaps accurately) from somewhere that EA stores all graphics internally in PNG format. Nonetheless, it seems that EA does not recognize or handle transparent backgrounds.
I hope I'm wrong, and that EA will somehow do this with imported metafiles, but I don't have any appropriate examples to test with.
JohnDoe
  • EA rocks !
« Reply #6 on: June 20, 2007, 03:42:10 am »
It would be helpful to understand, what file format is inside that Base64 CDATA segments inside the image gallery. Is it EMF, WMF, PNG or whatever ?
Regards
Bernd
« Last Edit: June 20, 2007, 03:42:34 am by BerndWill »
JohnDoe
  • EA rocks !
image transparency using Visio
« Reply #7 on: June 20, 2007, 09:19:58 pm »
I finally found a way to import transparent pictures into EA:
Visio:
- open Visio, select a template and create a new document
- drag a shape onto the stage
- mark the shape
- File -> Save As
- save the shape using file format "Enhanced Metafile"
EA:
- open Enterprise Architect
- Settings -> Images
- "Add new"
Now you have a transparent shape loaded into EA.
Regards
Bernd
« Last Edit: June 20, 2007, 09:20:18 pm by BerndWill »
Cavan “Kevin” G. Watson
« Reply #8 on: June 21, 2007, 01:39:06 am »
 :o A use for Visio... See ya needs it after all
Well it cheered me up this morning
Kevin
thomaskilian
  • Guest
Re: image transparency using Visio
« Reply #9 on: June 21, 2007, 05:10:52 am »
As I said. I use Metafile Companion which was once a freeware tool...
Hans
« Reply #10 on: June 21, 2007, 01:23:54 pm »
Hi Bernd and Thomas,
thanks alot for your input: that questions nagged me for years!
Regards
Hans
jeshaw2
  • I'm a Singleton, what pattern are you?
« Reply #11 on: June 21, 2007, 05:10:43 pm »
Are you'all sure its an EA problem?
MS/IE browser didn't handle png formats correctly until IE/7.
Verbal Use Cases aren't worth the paper they are written upon.
