Author Topic: Checkout from plugin problem  (Read 3517 times)
brannstrom
« on: May 13, 2008, 06:07:48 pm »
Hi!
When I checkout a version controlled package with the VersionControlCheckout function and then try to access diagrams in the package I get some strange problems. If I look at the package.Diagrams.Count I get 10 diagrams, which is right. But when I try to access a diagram an error is thrown. If I do a package.Diagrams.Refresh() then the Count say that there are zero diagrams. What should I do to be able to work with the package after a checkout.
I also think I found a documentation error. The notes on the functions have been mixed up.
VersionControlCheckout (String Comment)
 Void
 Removes version control from the package. Throws an exception if the operation fails. Use GetLastError( ) to retrieve error information.
VersionControlRemove ( )
 Void
 Perform checkout of the version controlled package. Throws an exception if the operation fails. Use GetLastError( ) to retrieve error information.
Parameters:
Comment: String - Log message that is added to the version controlled file's history (where applicable).
/N
RoyC
  • Read The Help!
Re: Checkout from plugin problem
« Reply #1 on: May 14, 2008, 09:48:42 am »
Thanks for posting the document error. I have corrected it and the changes should be apparent in the next release of EA.
Best Regards, Roy
