Author Topic: Annotations and associations  (Read 2507 times)
korsbecker
« on: March 04, 2008, 05:33:16 pm »
Hi
I have a problem with adding annotations on setters for properties coming from associations also I have a problem with generation getters and setters coming from associations.
I have to classes A and B. A got one attribute a1 and I marked it "Property" which secures generation of getters and setters when I generate code and this is fine. Between A and B there is an association. When I generate code directly from the model no getters and setters are generated, it seems that I have to make a transformation in order to get the getters and setter???? Is there any other way of securing generation of getters and setters?
Anyway if the association between class A and B is a one-to-many I need to annotate the setter with the following:
  @OneToMany(
    cascade={CascadeType.ALL},
    fetch=FetchType.EAGER
  @JoinColumn(name="[setter attribute]")
What is the easiest way of doing this?
Henrik :-)
