Author Topic: Drawing Sequence diagram from an addin  (Read 3336 times)
Krzysztof Swiatkowski
  • Understanding is a three-edged sword
« on: August 10, 2008, 08:13:36 am »
Hi
I would like to know if it is possible to create sequence diagram from addin code.
I need to write addin that will be able to combine diagrams from different projects.
At first glance I would need to create Sequence relations but how can I order them in different objects so that the output on a diagram made sense?
How can I insert a message between other messages?
Or add interaction occurence objects in a diagram?
Thanks in advance
Kris
If I put you finger in the eye
then you have finger in the eye
and I have finger in the eye
but it's not the same
