Author Topic: MDG Link for Eclipse Version 1.5  (Read 19129 times)
sparks
« on: October 03, 2006, 11:48:22 pm »
Sparx Systems MDG Link for Eclipse 1.5
Release Notes for MDG Link for Eclipse 1.5
Added support for synchronization of enum definitions for Java 1.5
Added support for user defined command line parameters when opening Eclipse
Improved handling data conttaining Multi-Byte characters
Improved forward merge/synchronization process
Improved 'View Source' functionality (to handle multiple constructors and more accurate method/field location)
Minor optimisations to improve overall performance
Release Notes for MDG Link for Eclipse 1.0.19
Fixed two bugs introduced in 1.0.18
 - Classes at root level caused error on merging.
 - Classes in sub-packages would re-appear in merge dialog after successful merge.
Both fixes affect org.sparx.mdg.eclipse_1.0.19.jar only - the EA Add-In DLL was unchanged from 1.0.18.
Release Notes for MDG Link for Eclipse 1.0.18
Encapsulated Plugin into a single jar file that the user needs to copy to the plug-in folder (org.sparx.mdg.eclipse_1.0.18.jar).
Add-In DLL version number updated to 1.0.18 to correspond with Eclipse Plug-in.
