Author Topic: Example of API use in C# for SQL access  (Read 4224 times)
Andy B
« on: November 03, 2008, 10:56:52 pm »
Hi
Does anyone have an example of how to connect to an EA repository implemented in SQL server via C#? I can connect to an EAP (via OpenFile) but can't seem to find the equivalent syntax to connect to the SQL repo.
Thanks.
Re: Example of API use in C# for SQL access
« Reply #1 on: November 05, 2008, 07:52:57 am »
You use the same function, but pass in the connection string.
Andy B
« Reply #2 on: November 05, 2008, 07:58:26 am »
thanks - that has done it
