Author Topic: Odd auto-num with MS SQL 2008  (Read 2303 times)
moun
« on: November 22, 2010, 04:22:47 am »
Hi, I am a newbie to Enterprise Architect. I have a problem with column properties in DDL diagram, particularly in case of MS SQL 2008.
My default database is MS SQL 2008 and I have generated a couple of tables by transformation from class diagrams. I need to set up the properties like auto numbering, however there is nothing in Column properties dialog. Everything works fine when the environment is set to other databases (including MS SQL 2005).
Moreover, if I generate the DDL for MS SQL 2005 by transformation from Class diagram and then I switch the individual tables to MS SQL 2008, everything works fine, so it looks like a bug.
Is MS SQL 2008 fully supported?
Tom
