Author Topic: Show which source file implements which Class?  (Read 3043 times)
tonyhedge
« on: January 22, 2012, 09:57:45 pm »
I have a model where my Classes are linked to C++ source files through Code Engineering.
For each class, I can see the source file to which it is linked via View/Element Properties/Class Settings/Filename.
What I would really like to do is generate some sort of diagram or report showing the mapping of Class to Source File for all the Classes in my project.
So far I can't find any way of doing so.
Any suggestions warmly welcomed!
Regards
Tony
"Interrupts happen!"
Re: Show which source file implements which Class?
« Reply #1 on: January 23, 2012, 09:42:41 am »
Use a custom SQL search. Something like this should do the trick:
SELECT ea_guid AS CLASSGUID,Name,Genfile
FROM t_object
WHERE Genfile<>''
ORDER BY Name
(To run this search, go Edit > Model Search, click the "Builder" button, open the "SQL" tab, paste the above command into the text area, and click "Run")
tonyhedge
« Reply #2 on: January 23, 2012, 09:17:57 pm »
Thanks KP - I'll give it a go (and given my level of competence with SQL, I'll probably be back!).
Thanks again
Tony
[Edited to add - excellent - works perfectly, thanks]
« Last Edit: January 23, 2012, 10:36:42 pm by tonyhedge »
