Author Topic: Reverse Engineering  (Read 4406 times)
zalbina
Reverse Engineering
« on: October 10, 2012, 06:42:36 am »
This is a problem: how can I control design and code when we are changing directory pretty often? For example: I've generated some Java code, made some changes to this file and move it to the different directory and after that "Synchronize with code..." option is chosen. Nothing happened, I will not see the changes in the EA because I've moved the file to other place.
May I contol all these manipulations?
Thanks.
Cavan “Kevin” G. Watson
Re: Reverse Engineering
« Reply #1 on: October 10, 2012, 11:02:26 am »
Does that really make sense to you?  What your doing I mean.
I think you really ought to look into a better source control activity than manual labour like that.
Try Microsoft Team Foundation online Service, TFS 2012 introduces local work stores as default.  Check the stuff out, do your magic, check the stuff in, comment and local Wipe.
How often have you not moved everything and oops!!!
... And you model too yeah, regards :exclamation
zalbina
« Reply #2 on: October 10, 2012, 06:38:50 pm »
Not much. Nothing to do with EA?
