Author Topic: How to add an Interface element with "Use circle  (Read 5857 times)
Jing Zhang
« on: May 15, 2009, 01:55:30 am »
Hi All,
I am trying to add an Interface element with “Use Circle Notation” by using Interop.EA in C# (My EA version is 7.1.833); I went through all the properties/methods of both Element and DiagramObject in the help file, but I just can not figure it out.  I noticed the Style property of the DiagramObject is something like "DUID=A56A3FFE;Lollipop=1;" if the element is set to “Use Circle Notation”, and it will be first half – something like "DUID=A56A3FFE;” if the element is not set to “Use Circle Notation”. But if I set Style property of DiagramObject in code as below, the element added is still not using circle notation.
//create a new Diagram at current selected package
EA.Package currentPackage = Repository.GetTreeSelectedPackage();
EA.Diagram newDiagram = (EA.Diagram)currentPackage.Diagrams.AddNew("ESB Queues Deployment Diagram", "Deployment");
newDiagram.Notes = "This daigram is used for document ESB queues.";
newDiagram.Update();
//create a new cluster node
EA.Element newClusterElement = (EA.Element)currentPackage.Elements.AddNew("prodcluster", "Component");
newClusterElement.Stereotype = "Cluster";
newClusterElement.Update();
//create all elements for Queues
EA.Element newQueueElement = (EA.Element)currentPackage.Elements.AddNew("Queue1", "Interface");
newQueueElement.Stereotype = "JMS";
newQueueElement.Update();
//add elments to diagram
EA.DiagramObject newClusterDiagramObject = (EA.DiagramObject)newDiagram.DiagramObjects.AddNew("l=200;r=400;t=200;b=600;", "");
newClusterDiagramObject.ElementID = newClusterElement.ElementID;
newClusterDiagramObject.Update();
EA.DiagramObject newQueueDiagramObject = (EA.DiagramObject)newDiagram.DiagramObjects.AddNew("l=200;r=400;t=300;b=600;", "");
newQueueDiagramObject.ElementID = newQueueElement.ElementID;
newQueueDiagramObject.Update();
newQueueElement.Refresh();
String oldStyle = newQueueDiagramObject.Style.ToString();
newQueueDiagramObject.Style = oldStyle + "Lollipop = 1;";
//add connection between cluster and queue
EA.Connector newConnector = (EA.Connector)newClusterElement.Connectors.AddNew("", "CommunicationPath");
newConnector.SupplierID = newQueueElement.ElementID;
newConnector.Direction = "Unspecified";
newConnector.Update();
newClusterElement.Connectors.Refresh();
If anyone can provide any hint on this, it would be very much appreciated.
Have a nice day!
Jing Zhang
« Last Edit: May 15, 2009, 02:09:05 am by jz247 »
Cavan “Kevin” G. Watson
Re: How to add an Interface element with "Use circ
« Reply #1 on: May 15, 2009, 06:41:57 am »
Hey...  ;D :)
Don't any of you folks use a visual / graphical notation....
The text even looks dull... which isn't a great motivator
A graphical non sequence diagram representation might even enable you to solve the issue unaided.
Thankyou for highlighting the issue; but not only do 'Sparxians' dislike the Windows Fluent or Office Ribbon interface style ( could just be an 'OZie' thing )... but it's graphical tool users,  "think text", not pictures or animated  timelines...
my mate says that internally they have parser... but as one adminy personality said " much auto-regenerated material is dificult " ( [smiley=2vrolijk_08.gif] all that converting to text takes it toll on any cognitive system [smiley=2vrolijk_08.gif] to understand... highlighting lines of text in todays debugger environments ( single step.. even point at symbol labels and read values "in text"....
ITS HOW YOU CHOICE TO ILLUSTRATE.... petulant rant over :'(
« Reply #2 on: May 15, 2009, 06:47:36 am »
Is this something to do with not calling refresh after each update...
I'm trying to be helpfull
KP
« Reply #3 on: May 15, 2009, 09:15:04 am »
I don't know if this is the issue, but there probably shouldn't be any spaces in "Lollipop=1;"
The Sparx Team
[email protected]
