Author Topic: Specify label position in ShapeScript  (Read 3152 times)
McMannus
« on: May 16, 2013, 11:24:51 pm »
Good afternoon,
I'm currently trying to create a custom shapescript for a stereotype derived from Port.
shape main{
 startpath();
 rectangle(0,0,100,100);
 endpath();
 setfillcolor(0,0,0);
 fillandstrokepath();
shape label {
      if (hasproperty("parentedge","top"))
            setorigin("NE",0,0);
            println("top");
      if (hasproperty("parentedge","bottom"))
            setorigin("SE",0,0);
            println("bottom");
      if (hasproperty("parentedge","left"))
            setorigin("NW",0,0);
            println("left");
      if (hasproperty("parentedge","right"))
            println("right");
As you probably see, I want the port's label to change its relative position depending on the ports position relative to its parent element. The text of the labels is always correct, so that I can assume that the right if statement is entered! But the position change doesn't work at all.
1) How does setorigin() work?
2) Where is the reference origin to which I specify the offsets?
3) Is setorigin() the right method to do the job?
Thanks in advance!
