Author Topic: Keystore Service Default Listening Port  (Read 9539 times)
TVail
« on: February 27, 2014, 03:12:52 am »
In the documentation for the Keystore service, it states that the service listens on port 7770 by default.  The documentation also shows how you can configure the service (via the keystoreService.config file) to listen on a different port.
If the service listens by default on Port 7770, does that also mean that Enterprise Architect tries to connect to the service on that same port by default?  If so, how do you change the port that Enterprise Architect uses to connect to the service if you change the listening port on the server?
Re: Keystore Service Default Listening Port
« Reply #1 on: February 27, 2014, 08:40:49 am »
Without having recently tried, I would say to append ':<port number>' to your server name/address.
