Author Topic: Information item on Information flow  (Read 4175 times)
Glassboy
« on: July 28, 2014, 07:25:11 am »
When you create an information flow between two elements you can add information items to the flow.  Is there a way to return these information items in an RTF report?
I'm looking for a way to produce a list of required fire wall burns, and it would seem to be handy if I can create the port\protocols as information items and attach them in information flows between nodes and then report on them.
Helmut Ortmann
Re: Information item on Information flow
« Reply #1 on: July 28, 2014, 08:08:29 am »
if nothing works for *.rtf you may:
- Create a Fragment Template
- Create a fragment script (see online help and example.eap)
- Call the fragment from your template
It may be possible that you can only do this for elements and not for connectors. Fragment scripts are only working fine with EA11.
Helmut
