Author Topic: Auto-naming feature in a shared model in SVN  (Read 2426 times)
BashHill
« on: October 25, 2014, 02:54:56 am »
We've set up a shared model in SVN using XML files for each package in the model, auto-named by EA using package GUIDs. The .eap file is also checked in. How does the auto-naming feature work, i.e. how is the next available number propagated to all team members? If for example two users add a new auto numbered Requirement element to the model, how are the numbers allocated so that they don't collide?
Re: Auto-naming feature in a shared model in SVN
« Reply #1 on: October 25, 2014, 03:35:26 am »
It probably won't work if you have distribute EAP files. That will only work correctly for a single central database.
