Author Topic: Deleting an object  (Read 11593 times)
Bruno.Cossi
Deleting an object
« on: December 10, 2003, 01:36:20 pm »
When deleteing an object (in the Project Browser, not only removing it from a diagram), if the object has any links, I would like a confirmation box to popup with something like "This object is linked to.... Are you sure you want to delete it?". Especially in a multi-user environment, with Use Cases or other objects being re-used multiple times, this would be extremely helpful!
Bruno
Tjerk
Re: Deleting an object
« Reply #1 on: December 11, 2003, 12:34:12 am »
Hi Bruno,
Do you know that the Relationships window can be used to show the existing relations for the item you want to delete?
Greetings,
Tjerk
Bruno.Cossi
« Reply #2 on: December 11, 2003, 02:21:24 pm »
Hi Tjerk,
yes, I know it.... you can also see them in the "Links" section of the "Properties" window. However the simple question would save a lot of time and potential hassle.
Thanks!
Bruno
