Author Topic: Reverse Engineering - Pause  (Read 4007 times)
Hugo
  • Where there's a will there's a way.
« on: August 25, 2006, 11:51:06 am »
In the reverse engineering window, add a "Pause" button to allow user to suspend the revers processing.
Currently it runs on its own and diagnostics just scroll past.
It wd be neat to be able to pause this and then freely scroll up/down the diagnistics just to see what its happening, it may be that one may decide to cancel the whole conversion process but unless they can see and read at leisure they will miss this possibility.
H
« Last Edit: August 25, 2006, 12:20:24 pm by Hugo »
Re: Reverse Engineering - Pause
« Reply #1 on: August 28, 2006, 03:56:34 am »
Or instead consider to include an option for writing the log (and transform and fwd engineer) to a file/the system output. As you have this System Output tab, it would be logic to send all logging there.
