Author Topic: Association.isDerived as a regular property  (Read 4113 times)
« on: March 24, 2009, 07:48:26 pm »
After a little queeste I finally found how to make an association derived. Apparently the isDerived property of an association has to be set via advanced/custom properties.
This is far from intuitive and not documented in the user guide.
I only found the solution by searching the forum.
I propose to add a tickbox "Derived" in the association (connector) properties dialog.
