Author Topic: 8.0 Resizable dialogues  (Read 48379 times)
8.0 Resizable dialogues: Settings | Template Packa
« Reply #15 on: March 21, 2011, 11:42:19 am »
and many other settings dialogues
RoyC
  • Read The Help!
Re: 8.0 Resizable dialogues
« Reply #16 on: March 21, 2011, 01:52:45 pm »
Michael Fraser offered to keep an eye on these resizable dialog requests, and to act on them if possible. However, Michael - like Elvis - has left the building (but thankfully not, like Elvis, this life).
Can you please ensure that these requests are also directed to Sparx Support as Feature Requests or Bug Reports? Thanks.
Best Regards, Roy
« Reply #17 on: March 21, 2011, 02:04:15 pm »
Sure, bug requests it is. ta
« Last Edit: March 21, 2011, 02:07:03 pm by skiwi »
Re: 8.0 Resizable dialogues: Project transfer
« Reply #18 on: March 21, 2011, 02:54:15 pm »
Note that source and target projects do not event show the full path and file name, so should be improved.
As for the log file, why can't I see the full file descriptor?
You should have seen how small it was before I got Sparx to make it this good!   But your point about the log file is well made.  I was just delirious with getting the projects to be big enough to be meaningful to "push my luck".
« Reply #19 on: April 06, 2011, 06:51:23 pm »
Message properties (in sequence diagrams) are not resizable (even in V9). Very bad as we have long method names that differ only in chars not visible in the dropdown.
Re: 8.0 Resizable dialogues: database data types
« Reply #20 on: April 13, 2011, 12:27:16 pm »
PS Can we add columns, eg a column for common type
mrf
« Reply #21 on: May 05, 2011, 11:41:08 pm »
If only someone had said thankyou on the forums for making all those dialogs resizable.... :p
Best Regards,
Michael
[email protected]
"It is more complicated than you think." - RFC 1925, Section 2.8
« Reply #22 on: May 06, 2011, 01:18:21 am »
Thank you? Why haven't they been designed resizable from the beginning? Just for sake of getting a "Thank you"?
« Last Edit: May 06, 2011, 01:19:16 am by qwerty »
Graham_Moir
« Reply #23 on: May 06, 2011, 01:36:50 am »
Thank you.
« Reply #24 on: May 06, 2011, 06:19:30 am »
Thank you too, keep up the good work
Re: 9 Resizable dialogues: Foreign key constraint
« Reply #25 on: August 20, 2012, 01:36:36 pm »
reported
Re: 9 Resizable dialogues: Edit Stylesheet
« Reply #26 on: September 03, 2012, 02:15:04 pm »
Another one that it would be good to be able to resize,
or larger in the first place
« Last Edit: September 03, 2012, 02:15:40 pm by skiwi »
Re: 8.0 Resizable dialogues: MDG
« Reply #27 on: September 12, 2012, 09:50:49 am »
MDG link for Visio Setup dialogue; if I could resize it I could read it
link for Visio
Re: 9.3 Resizable dialogues: UML types
« Reply #28 on: September 24, 2012, 11:32:16 am »
Resize UML Types
9.3  Resizable dialogues - add
« Reply #29 on: February 01, 2013, 03:01:59 pm »
filters
