Author Topic: Find in Diagram  (Read 3735 times)
neil_albiston
Find in Diagram
« on: December 18, 2010, 04:47:27 am »
Is there an efficient way to do a script version of the Element --> Find In Diagrams menu item?
So far the only option I've found is to check the Ids of every diagram object in every diagram. Not ideal.
Basically I want to check an element is not included in any  diagrams before it is deleted. Any suggestions?
Thank you in advance,
Neil
Re: Find in Diagram
« Reply #1 on: December 19, 2010, 02:53:43 pm »
Neil,
In that case I'd use SQL. Something like
myRepository.SQLQuery("select Diagram_ID from t_diagramobjects where Object_ID = " + myObjectID.ToString());Should give you diagramID's of all diagrams using this object in a fraction of a second.
neil_albiston
Re: Find in Diagram
« Reply #2 on: January 05, 2011, 03:24:43 am »
Thank you Geert.
Yet again one of your answers has solved my problem and opened up an entire undocumented chapter of possibilities.
... You should write a book.... I'd buy it.
Cheers,
Neil
Re: Find in Diagram
« Reply #3 on: January 05, 2011, 07:13:16 pm »
Honestly, I've been thinking about that, but then again I don't seem to find the time.
Maybe I could start with some EA related blog posts...  :)
