Author Topic: Problems doing layout of a diagram  (Read 3418 times)
Johan Too
« on: February 02, 2011, 03:27:49 am »
Hi I have code that is basically doing
foeach(obj in diagram.DiagramModels) {
        obj.left = x;
        obj.right = x + width;
        obj.top = y;
        obj.bottom = y + height;
        obj.Update();
diagram.Update();
the result is that all the diagram objects end up in the top left corner, except for a few that aren't... it isn't clear to me why this is happening or why a few do get a different position (and size).
If I run through the code a second time, the positions calculated by the logic are already in the left, right, top, bottom attributes, so it seems these are set correctly.
Any suggestions about what I am doing wrong?
« Last Edit: February 02, 2011, 03:31:54 am by jov »
Re: Problems doing layout of a diagram
« Reply #1 on: February 02, 2011, 08:36:04 am »
What kind of values are you putting in?
Note, the y coordinates start at zero and move negative.  So unless your height variable is negative that is one error.
Johan Too
« Reply #2 on: February 02, 2011, 11:53:36 pm »
Hello Simon,
thank you for the reply!
Changing my height values to negative solved my problem :).
For completeness, the values are around 100 to 200 or so.
