Author Topic: Implementation path for C code generation  (Read 4758 times)
PaoloD
« on: November 19, 2016, 01:30:04 am »
Hello
I'm trying to generate .C files on a different path from .H files.
I would like to generate implementation files in a relative path to H ones, with the class name in the path.
I mean, if I've class MyClass1 and MyClass2 generating C:\sourcePath\include\MyClass1.h and C:\sourcePath\include\MyClass2.h  I'd like to get the implementation in relative path ..\className\className.c.
Resulting in the two implementation files C:\sourcePath\MyClass1\MyClass1.c and C:\sourcePath\MyClass2\MyClass2.c
I'm working on the "Source Path" of the Source Code Engineering options, but I'm not getting it...
Can anyone help?
Thanks!
Re: Implementation path for C code generation
« Reply #1 on: November 21, 2016, 08:44:37 am »
You want the source for every class in its own directory?
I don't think the automatic naming can do that. If I had the need I would write a script to set that filepaths of classes within a package. (And if necessary write an add-in to do that for elements on creation)
PaoloD
« Reply #2 on: November 21, 2016, 09:33:05 pm »
Yes, the requirement I'm facing is to have a modular implementation for each class, bounded to its own folder.
The scripting solution was the last hope for me. I was trying some trick with macro substitution into "Source Path" in the Source Code Engineering options, but according to your answer the tool can't do that directly.
