Author Topic: MDG - change diagram icon  (Read 5191 times)
sig550
« on: December 07, 2017, 03:07:52 am »
Hello everybody,
is it possible to change the icon from a diagram? The diagram I specified displays the icon of a class diagram. However, I want to display the icon of an analysis diagram.
I suppose I have to add an attribute to the stereotype or the metaclass.
(For example, the icon appears on the left of the diagram types when a diagram is added to a package.)
Thanks a lot.
Best regards
sig550
Uffe
Re: MDG - change diagram icon
« Reply #1 on: December 07, 2017, 03:09:53 am »
The icon is not configurable. Instead, extend the diagram type that has the icon you want.
/Uffe
sig550
« Reply #2 on: December 07, 2017, 03:33:53 am »
Thank you for your prompt reply.
Are there other attributes that are inherited by the extend?
If I extend another diagram, I have no way to use my own toolboxes. Because the corresponding attributes can be defined only in a metaclass.
« Last Edit: December 07, 2017, 03:38:59 am by sig550 »
sig550
« Reply #3 on: December 07, 2017, 08:06:31 pm »
now I get it. I have to give the appropriate name to the metaclass. In my case, the name is "Diagram_Analysis".
Best regards
sig550
Uffe
« Reply #4 on: December 07, 2017, 11:23:36 pm »
Yes, exactly.
As to other characteristics, well there are three basic types of diagram in terms of behaviour: "normal", sequence and timing. This type is not represented in any way as far as I know, it's just there. I assume that's inherited.
Other than that, most diagram characteristics can be specified with the styleex, pdata and other attributes.
/Uffe
