Author Topic: Automatically generated diagram in Use Case report  (Read 3414 times)
PaulV
« on: January 13, 2012, 10:10:05 pm »
I want to generate RTF documentation from Use Case model. The model contains some use case with structured scenarios. An activity diagram is generated (Use Case properties/Scenarios/Generate Diagram) from this scenario; such diagram is placed by EA under specially project node with Activity type within other activities represent structured scenario steps.
I use a template derived from the standard (use case scenario template). My problem is a following: the diagram generated by EA and placed under intern Activity node does not appears in the RTF document because activity elements are excluded by default (“Generate documentation dialog / Options) for this template. If I include activity elements into report, they appear as “use case” :( . If I move the diagram from its activity project node, this diagram appears in the document but will not be automatically updated by EA from scenario editor. I tried some filters for activity items but unsuccessful. :(
Can anyone give a tip? Thx
