Author Topic: Search within project or package  (Read 3831 times)
« on: June 07, 2019, 08:42:22 am »
I want use the simple/common search (ctrl-f) or similar [Start > Search > ...]
and restrict the results, or be able to group the results, by model, project, or package?
Common search doesn't have a column for package at a level, so difficult to group by it.
Search browse for package doesn't provide for search with package,
any ideas?
tia
Simon
Re: Search within project or package
« Reply #1 on: June 07, 2019, 01:26:39 pm »
I guess you'll have to resort to SQL searched to be able to do that.
There you can do things like
select * from t_object o where o.package_ID in (#Branch#)
Mauricio Moya (Arquesoft)
    • Arquehub Azure Module
« Reply #2 on: June 07, 2019, 10:14:04 pm »
I think the option you are looking for is in the search window: click the 4th button in the search (Edit search), then the 5th button in the edit search section (search options), then it opens a window in which you can select the option "Return matching items for the entire model" or "Return matching items for the selected Package".
