Author Topic: UML Profiles and Scripts  (Read 4200 times)
Uwe Krüger
« on: July 31, 2012, 05:21:07 pm »
We use UML Profiles with tagged values. For an element with the UML Profile applied, I can access the tagged values in a script, identification can be done by the (readonly) FQName “Namespace::Name”. But how can I apply the UML Profile from within a script. Setting the stereotype doesn’t help, as I cannot add the tagged values with the right FQName. As a workaround I have split my script into two and I run the first script, then apply the Profile, then run the second script, but I think there should be a better way.
Can anyone give me a clue?
Thanks in advance
Uwe
Re: UML Profiles and Scripts
« Reply #1 on: July 31, 2012, 06:48:21 pm »
Try
bool Repository.SynchProfile (string Profile, string Stereotype)
— Synchronizes Tagged Values and constraints of the UML Profile for Stereotype.
« Last Edit: July 31, 2012, 06:49:09 pm by qwerty »
Uwe Krüger
« Reply #2 on: July 31, 2012, 09:17:58 pm »
Thank you. This is what I was looking for, works fine for me.
