Author Topic: Generate class diagram from XSD  (Read 2608 times)
Michel777
« on: July 27, 2022, 07:34:11 pm »
I have a complex (e.g. extensions) and large  (> 5000 lines) XML schema definition.  Question is there any limitation  for generating  XSD -> UML class diagram ?
Michel
Re: Generate class diagram from XSD
« Reply #1 on: July 28, 2022, 01:50:19 am »
There's not really any technical limit for that. However, if you let a machine create a diagram with that amount of elements you need a machine to understand it. A human will probably just run away when seeing it.
