Author Topic: Failed to load Matlab. Module Not found.  (Read 3337 times)
Chrispo
« on: March 25, 2023, 02:35:18 am »
Hi fellow forumgoers,
Today I was experimenting with Matlab simulation within EA. When using the expression ''Expression: var matlab = new Solver("matlab");'' in a state machine diagram the following results are given by the simulation interface.
[373592954]      Attempting to load MATLAB from installed registry path: C:\Program Files\MATLAB\R2023a
[373592957]      Failed to load Matlab. Module Not found.
[373592960]      Failed to load Matlab. Module Not found.
[373592961]      SIMULATION ERROR: Processor launch error: Failed to load Matlab. Module Not found.
This expression is the first step of the simulation and immidiately fails. When checking the directory I notice EA instantly has the right directory chosen but just won't work.
Has someone experienced the same problem?
Kind regards,
Christian
