Author Topic: Limited Glossary Based on Report Content Only  (Read 4901 times)
gash272
« on: June 24, 2024, 09:21:19 pm »
Hi, I know from the forum history that this question has been asked before, but apart from a third party tool, is there a way to limit the report generated glossary to list only the terms relevant (that appear in) in the report that is generated?
Thanks in advance
Re: Limited Glossary Based on Report Content Only
« Reply #1 on: June 24, 2024, 09:35:22 pm »
I don't think this has changed recently.
gash272
« Reply #2 on: June 28, 2024, 08:54:07 pm »
Fair enough. Could you limit what is generated from the glossary based on the glossary type field? i.e. could I include all "Type: Acronyms" but ignore all glossary items with "Type: System"?
« Reply #3 on: June 28, 2024, 09:19:42 pm »
You definitely can if you use an SQL fragment, but I'm not sure if you can do that with the standard templates.
ea0522
« Reply #4 on: July 01, 2024, 08:55:46 pm »
Just a thought:
You could probably use the generated Glossary items in a Word-like index table and filter out all elements which are not indexed properly (i.e. not used anywhere)?
gash272
« Reply #5 on: July 10, 2024, 11:37:46 pm »
How do you create/add an index to an EA generated document ? or do you mean add an index in Word after the document was generated?
