Author Topic: central repository  (Read 4210 times)
soren
central repository
« on: November 27, 2008, 12:14:52 am »
I have a problem when I want to start Enterprise Architect. If I work locally on the machine, the application works fine. But if I want to connect with the central respository, it askes for a password. When i start the eap file, I get this error:
enter password:
Enterprise architect is installed on several machines, but the problem not always occurs.
Does anybody know the solution for this problem?
thx!
Oliver F.
  • ArenĀ“t we all in the model business ?
    • Karl Storz homepage
Re: central repository
« Reply #1 on: November 27, 2008, 04:22:33 am »
When entering the database connection details and giving the DB password the first time in the setup dialog there is a checkbox to store the password. You should set this.
Under some circumstances (namely after a network disconnect of your machine) it might ask for the DB password again and brings a SQL connection error no matter what you enter even when the network connection had been restored.
However it dows not seem to have implications on current work as after acknowledge it works as before.
Just make sure to have the checkbox tipped.
