Author Topic: 'How can I use Package's Element to get Package's  (Read 11202 times)
alvinhsieh
« on: July 12, 2006, 07:47:34 pm »
HI,
'How can I use Package's Element to get Package's PackageGUID ???
'in some case  The Package's Element's ElementGUID  is not EQ. Package's PackageGUID ???
'EA 6.1-B791,JET3.5 , VB6
Public Function Check_Package(ByVal o_package As EA.package) As String
Dim pkg As EA.package
Dim C_package As EA.package
Dim x As Integer
Dim Elm As EA.Element
Set Elm = o_package.Element
  If Elm.ElementGUID <> o_package.PackageGUID Then
  Stop
 End If
   For x = 0 To o_package.Packages.count - 1
      Set pkg = o_package.Packages.GetAt(x)
        Call Check_Package(pkg)
        DoEvents
   Next
End Function
Re: 'How can I use Package's Element to get Packag
« Reply #1 on: July 13, 2006, 04:34:43 am »
The package's Element attribute returns an element. This is to allow you to retrieve those properties of the package that are common to all UML elements. However, the package-specific features of the package should still be addressed using the Package element itself.
The can be a bit confusing, since both a Package and an Element can have a Packages collection, for example. As a rule of thumb - on which I might well be corrected by Sparx of other users - if the Package class provides the attribute or operation you need use that. Only use the Package.Element property if there is nothing offered at the Package level.
HTH, David
